Cannot get any results or updates from EPiServer / Optimizely Nuget feed in Visual Studio
When I am trying to use Visual Studio to retrieve available versions for EPiServer components, I do not get any results.
So basically I am staying on the versions already installed (e,g. EPiServer.CMS 11.14.2)
This is the source I am using in Package Manager Settings in VS :
https://nuget.optimizely.com/feed/packages.svc
Is there a need to authenticate to the feed in some way, and how would i do that?
#296864
Feb 20, 2023 13:23
Eric Herlitz - Feb 20, 2023 14:27
Do you have any nuget.config-file in your solution? In that case check that file and ensure the config is correct.
It should be https://nuget.optimizely.com/feed/packages.svc
the link you posted is fed, not feed. that could be the issue.
#296867
Feb 20, 2023 13:58
Thanks. No, sorry, the link is correct. I misspelt it the first time, but I forgot to update he link after i corrected the text on the link.
The problem in VS persists. I.e. I do not get a list of available versions in "manage NuGet packages for solution" . The problem is there for the Optimizely feed only.  For packages coming from api.nuget.org, available versions are listed.
#296868
Feb 20, 2023 14:08
Can you post a screenshot of your Managing nuget packages window?
#296869
Feb 20, 2023 14:22
#296872
Feb 20, 2023 14:32
Did you consider switching the package source?
#296875
Feb 20, 2023 14:35
- Feb 20, 2023 14:38
Agree, this should be the culprit
Thanks, Eric and Quan! This solved it. "User error" on my part :(
#296877
Feb 20, 2023 14:51
Eric Herlitz - Feb 20, 2023 14:52
No worries, I can ensure you this has happend to all of us :)
