Update/Modify default Master language for a site
Hi Folks,
We are having multiple sites in our solution, and few of them are in production with “en” as a master language. But for one new site we want to set “en-us” as master language as we are not using “en” here.
To change the Master language, we used below SQL script, But it is working for pages only not for blocks. Could someone help on this, how we can modify/update the master langue for page dependents blocks also.
/****** Object:  StoredProcedure [dbo].[cogChangePageBranchMasterLanguage]    Script Date: 01/07/2013 14:49:59 ******/
IF  EXISTS (SELECT * FROM sys.objects WHERE object_id = OBJECT_ID(N'[dbo].[EPiCode_ChangePageBranchMasterLanguage]') AND type in (N'P', N'PC'))
DROP PROCEDURE [dbo].[EPiCode_ChangePageBranchMasterLanguage]
/****** Object:  StoredProcedure [dbo].[EPiCode_ChangePageBranchMasterLanguage]    Script Date: 01/07/2013 14:49:59 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE PROCEDURE [dbo].[EPiCode_ChangePageBranchMasterLanguage]
 @content_id    int,
 @language_branch varchar(20),
 @recursive bit,
 @switch_only bit
AS
DECLARE @language_branch_id nchar(17);
DECLARE @language_branch_nid int;
DECLARE @prev_language_branch_nid int;
DECLARE @child_Id int;
DECLARE @Fetch int;
DECLARE @target_lang_version_exist int;
SET @language_branch_nid = (SELECT pkID FROM tblLanguageBranch WHERE (LanguageID = @language_branch))
SET @language_branch_id = (SELECT LanguageID FROM tblLanguageBranch WHERE (LanguageID = @language_branch))
SET @prev_language_branch_nid = (SELECT fkMasterLanguageBranchID FROM tblContent WHERE pkID = @content_id)
SET @target_lang_version_exist = (SELECT count(*) FROM tblContentLanguage WHERE (fkContentID = @content_id AND fkLanguageBranchID = @language_branch_nid))
-- for switch only check if the page exist in the selected language and only then switch
IF 1 = @switch_only
  BEGIN
 print 'target_lang_version_exist' + str(@target_lang_version_exist);
 IF @target_lang_version_exist > 0
 BEGIN
 UPDATE tblContent
  SET fkMasterLanguageBranchID = @language_branch_nid
  WHERE pkID = @content_id AND fkMasterLanguageBranchID = @prev_language_branch_nid
 END
 ELSE
 BEGIN
 RAISERROR
 (N'The Selected page with ID:%d, cannot switch master branch since there is no version in the selected target language: %s.',
    11, 1, @content_id,  @language_branch);
 END
  END
ELSE
  BEGIN
 BEGIN
  RAISERROR
    (N'The Selected page with ID:%d, cannot be translated since there already is a version in the selected target language: %s.',
  END
 ELSE
  BEGIN
  UPDATE tblContent
    SET --fkLanguageID = @language_branch_id,
  UPDATE tblContentProperty
      SET fkLanguageBranchID = @language_branch_nid
  WHERE fkContentID = @content_id AND fkLanguageBranchID = @prev_language_branch_nid
  UPDATE tblContentLanguage
    --,fkLanguageID = @language_branch_id
  UPDATE tblWorkContent
  END
  END
IF 1 = @recursive
BEGIN
 DECLARE children_cursor CURSOR LOCAL FOR
  select pkID from tblContent where fkParentID = @content_id
 OPEN children_cursor
 FETCH NEXT FROM children_cursor INTO @child_Id
 SET @Fetch=@@FETCH_STATUS
 WHILE @Fetch = 0
 BEGIN
  print @child_id
  print @language_branch_id
  exec [dbo].[EPiCode_ChangePageBranchMasterLanguage] @child_id, @language_branch_id, @recursive, @switch_only
 END
 CLOSE children_cursor
 DEALLOCATE children_cursor
END
#286547
Sep 02, 2022 15:03
How many pages/blocks do you expect to be changed? updating using IContentRepository should be fast enough, while safer and more future proof
#286661
Sep 05, 2022 6:07
- Sep 05, 2022 8:10
Thank you for your reply, We want to change it for one of the sites from our Multisite solution(don't want to disturb them as they are using "en" as master and already gone live). Also, could you please explain bit in detail, how it will be done by using IContentRepository ?
My bad, I always thought it is possible to change Master Language for CMS content, which is turned out to be, not. One alternative is to copy the content and resave in a different master language. quite troublesome yes but much safer ...
#286663
Sep 05, 2022 10:24
Finally Got the below script that works for all blocks and pages.
/****** Object:  StoredProcedure [dbo].[EPiCode_ChangePageAndBlockBranchMasterLanguage]
 Script Date: 2022-07-11 14:26:38 ******/
SET ANSI_NULLS ON
GO
GO
CREATE PROCEDURE [dbo].[EPiCode_ChangePageAndBlockBranchMasterLanguage]
    @content_id    int,
    @recursive bit,
    @switch_only bit,
    @delete_old_language_id int
AS
DECLARE @Fetch int;
IF 1 = @switch_only
  BEGIN
    BEGIN
    UPDATE tblContent
        IF @delete_old_language_id > 0
        BEGIN
            --modify content properties which are not language specific
            update tblContentProperty set fkLanguageBranchId=@language_branch_nid where fkLanguageBranchID=@delete_old_language_id and fkContentId=@content_id and fkPropertyDefinitionID in (select pkId from tblPropertyDefinition where languagespecific=2)
            update tblWorkContentProperty set fkWorkContentId=(select [version] from tblContentLanguage where fkContentId=@content_id and fkLanguageBranchId=@language_branch_nid) where fkWorkContentId=(select [version] from tblContentLanguage where fkContentId=@content_id and fkLanguageBranchId=@delete_old_language_id) and fkPropertyDefinitionID in (select pkId from tblPropertyDefinition where languagespecific=2)
            --delete all old content
            delete from tblContentProperty where fkContentID=@content_id and fkLanguageBranchID=@delete_old_language_id
            delete from tblContentLanguage where fkContentID=@content_id and fkLanguageBranchID=@delete_old_language_id
        END
    END
    ELSE
    BEGIN
    RAISERROR
    END
  END
ELSE
  BEGIN
    BEGIN
      RAISERROR
      END
    ELSE
      BEGIN
        UPDATE tblContent
      END
  END
-- get all 'for this page' or 'for this block' blocks and call itself recursively
DECLARE children_block_switch_cursor CURSOR LOCAL FOR
    select pkID from tblContent where fkParentId IN (SELECT pkId FROM tblContent WHERE contentOwnerId =
    (SELECT ContentGUID FROM tblContent WHERE pkId=@content_id))
OPEN children_block_switch_cursor
FETCH NEXT FROM children_block_switch_cursor INTO @child_Id
WHILE @Fetch = 0
BEGIN
    print @child_id
    exec [dbo].[EPiCode_ChangePageAndBlockBranchMasterLanguage] @child_id, @language_branch_id, @recursive, @switch_only, @delete_old_language_id
END
CLOSE children_block_switch_cursor
DEALLOCATE children_block_switch_cursor
--call recursively for all child pages
IF 1 = @recursive
BEGIN
    WHILE @Fetch = 0
    BEGIN
        print @child_id
    END
END
#286707
Sep 06, 2022 11:27
