You will need to create some sort of scheduled job or tool to achieve this, setting defaults only works when first creating content. It does not replace / overwrite existing items.
Example below on how to achieve something like this (Done long time ago), you can use GetChildren rather than FindPagesWithCriteria but should get the jist of it
[ScheduledPlugIn(DisplayName = "Set Default Profile Seniority")]
public class SetDefaultProfileSeniority : ScheduledJobBase
private const int DefaultSeniority = 100;
private bool _stopSignaled;
protected readonly ISiteDefinitionRepository _siteDefinitionRepository;
protected readonly IContentRepository _contentRepository;
protected readonly IContentTypeRepository _contentTypeRepository;
protected readonly IPageCriteriaQueryService _searchPages;
protected readonly ILanguageBranchRepository _languageBranchRepository;
public SetDefaultProfileSeniority(
ISiteDefinitionRepository siteDefinitionRepository,
IContentRepository contentRepository,
IContentTypeRepository contentTypeRepository,
IPageCriteriaQueryService searchPages,
ILanguageBranchRepository languageBranchRepository)
GuardValidator.ValidateObject(siteDefinitionRepository);
GuardValidator.ValidateObject(contentRepository);
GuardValidator.ValidateObject(contentTypeRepository);
GuardValidator.ValidateObject(searchPages);
GuardValidator.ValidateObject(languageBranchRepository);
_siteDefinitionRepository = siteDefinitionRepository;
_contentRepository = contentRepository;
_contentTypeRepository = contentTypeRepository;
_searchPages = searchPages;
_languageBranchRepository = languageBranchRepository;
IsStoppable = true;
/// <summary>
/// Called when a user clicks on Stop for a manually started job, or when ASP.NET shuts down.
/// </summary>
public override void Stop()
_stopSignaled = true;
/// <summary>
/// Called when a scheduled job executes
/// </summary>
/// <returns>A status message to be stored in the database log and visible from admin mode</returns>
public override string Execute()
OnStatusChanged(string.Format("Starting execution of {0}", this.GetType()));
var updatedCounter = 0;
foreach (var site in _siteDefinitionRepository.List())
if (_stopSignaled)
return "Stop of job was called";
updatedCounter += ProcessSite(site);
return $"{updatedCounter} page(s) have been updated.";
public int ProcessSite(SiteDefinition site)
if (ContentReference.IsNullOrEmpty(site.RootPage))
return 0;
var contentType = _contentTypeRepository.Load(typeof(ProfilePage));
var productPageTypeCriterion = new PropertyCriteria
Name = "PageTypeID",
Type = PropertyDataType.PageType,
Value = contentType.ID.ToString(),
Condition = CompareCondition.Equal,
Required = true
var criteria = new PropertyCriteriaCollection { productPageTypeCriterion };
var pageDataCollection = _searchPages.FindPagesWithCriteria(
new PageReference { ID = site.StartPage.ID },
criteria);
var cultures = _languageBranchRepository.ListEnabled().Select(x => x.Culture);
var processedCounter = 0;
var progressTimer = new Timer(5000);
progressTimer.Elapsed += (o, e) =>
OnStatusChanged($"Processing site {site.Name} [{processedCounter} / {pageDataCollection.Count}]");
progressTimer.AutoReset = true;
progressTimer.Enabled = true;
foreach (var pageData in pageDataCollection)
foreach (var culture in cultures)
var page = _contentRepository.Get<ProfilePage>(pageData.ContentLink, culture);
if (ProcessProfilePage(page))
updatedCounter++;
processedCounter++;
progressTimer.Stop();
progressTimer.Dispose();
OnStatusChanged($"Processing site {site.Name} completed.");
return updatedCounter;
private bool ProcessProfilePage(ProfilePage page)
if (page is null || page.Seniority != default)
return false;
var clone = page.CreateWritableClone() as ProfilePage;
if (clone != null)
clone.Seniority = DefaultSeniority;
_contentRepository.Save(clone, SaveAction.Patch | SaveAction.SkipValidation);
return true;
return false;
Thank you for sharing this @Minesh!
I was able to repurpose your code to create a scheduled job to achieve exactly what I needed. Approx. 400 pages updated with a click of a button.
Or, if you could invert new bool property:
From "IsActive" => false when created
To "IsNotActive" => false when created; therefor true :)
Hello,
I have a page type called Interior Page. I added a new property for this page type, which is a checkbox.
I am able to set a default value for this property using SetDefaultValues:
newproperty = true;
However, the default value only works for newly created instances of Interior Page type.
I have 100s of already existing Interior Pages that need to have this new property set to the default value of true. How can I achieve this?
I tried defining the new property like below, but that didn't seem to do the trick:
public virtual bool NewProperty {
get => this.GetPropertyValue(page => page.newProperty);
set { this.SetPropertyValue(page => page.newProperty, true); }
Any suggestions on how I could set the default value for the new property on all existing pages of Interior Page type?
Thanks!
