Good day,
I'm very new to working with Dojo to change the look of the CMS. I'm trying to add a string with the block ID after the "Visible to": "All manage" in the top part of the if CMS editing.
But I don't really understand how this should happen - I tried widgets, but they only go into specific areas, I tried to look into EditorDescriptors, but it doesn't seem to be related, and only works on specific fields.
To be fair, I'm a bit lost here - any help would be great - idealy a suggestion and/or a code example. I did find the Dojo source files, but they are vert convoluted for a beginner like myself.
P.S. I do have experience with JavaScript, so I can understand Dojo syntax, but I couldn't find many tutorials to actually follow the logic between the C# code, plugin-ing into a specific area (which is which in my case?), what to write in the dojo file?
Thanks for any help
