Logout all users from episerver
I'm using azure active directory B2C as a login priovder with episerver 11, is there any way to bulk log out all users from episerver?
#276424
Mar 16, 2022 2:19
Not that I've heard of at least. Would be a cool feature to build though. A bit tricky especially with federated login.
#276666
Mar 18, 2022 10:13
If you're using cookies to store a auth token, you could try to alter its hashing method so that all cookie values become invalid.
#276847
Mar 22, 2022 11:08
I guess you could add some extra layer that you can also check against and clear data in that layer "on bulk logout" and then send any users part of the clearing through the signout process when they make the next request.
#279407
Apr 28, 2022 16:24
