Log warnings: Cannot save common property
Good morning everyone,
around midnight i have many log warnings from episerver. It seems to be related to the Epi-Forms. What is causing this?
Servername 2022-11-18 00:00:24,819 [292] WARN EPiServer.DataAccess.Internal.ContentSaveDB: Cannot save common property PartialSubmissionRetentionPeriod on non-master language de on content with id 5604_107217
Servername 2022-11-18 00:00:24,840 [292] WARN EPiServer.DataAccess.Internal.ContentSaveDB: Cannot save common property FinalizedSubmissionRetentionPeriod on non-master language de on content with id 5604_107217
..... (many Content-Ids)
Edit: It's not new, always in the night, is there a job running which is causing this? We have thousands of these entries.
Thanks in advance,
Tim
#291883
Edited, Nov 18, 2022 7:53
Every form has a retention policy, for it to clean up form submissions based on the values set a scheduled job is ran, the default settings for this job is to be ran a midnight every day. The Job is called  Form Submissions Cleanup.
You could try manually running this job to see if the same errors occur.
It might be worth raising a support ticket with Optimziely to see whats inside this Job and if it sets and property values during its run on the Form Contaner, it could be trying to see a value for a property which is not CultureSpecific on a non master langauge. (Or DotnetPeek)
#291887
Edited, Nov 18, 2022 10:29
Tim Schmelter - Nov 21, 2022 16:47
Thanks for the answer. But the jobs seems to run successfully always. I also have run it manually now, but no error or warning(not even in the log).
11/21/2022 4:37:04 PM 4m:46s Succeeded WEB069 0 expired submission(s) deleted. 0 submission(s) of removed form deleted.
