Do you have custom admin plugin, from the xml doc
I am able to reproduce this if I change LocalizationService.Current.FallbackBehavior to anything other than FallbackBehaviors.Echo or FallbackBehaviors.Null.
This happens because the "Display Options" plugin (EPiServer.UI.Edit.UserGuiSettings) has no description.
Do you change the value of LocalizationService.Current.FallbackBehavior anywhere in your code?
I'm having issues regarding My Settings page in Epi. This page seems to be working normally but after some time it starts throwing exceptions (500). After restarting application pool in IIS it again works correctly but after some time it crashes again.
Below is exception:
Here is my web.config localization section:
