Would it be possible to make two versions of the Local Block one which has Culture Specific Properties and another which does not, both these would inherit the Same Base Class for business logic purposes.
Or create a custom validation attribute stops the user from saving the block when its edited in a language other than the master language.
I have a page with two properties that use the same local block ArticlePageFilterBlock:
So all these properties in the local block should be CultureSpecific only in the second property of the page that uses them.
