Best way to convert LinkItemCollection to ContentArea?
There are several block types where I need to convert a LinkItemCollection property to a ContentArea property, what would be the easiest way to do this?
I have tried to just change the type from LinkItemCollection to ContentArea, but then the LinkItems only show as null objects in edit view.
Should I build a conversion job, or does anyone else have a better idea?
#269352
Jan 03, 2022 8:04
I think the best way is -
  1. Create a new ContentArea property
  2. Create A new BlockType with Link Property
  3. Create a scheduled Job to pull the data from the existing LinkItemCollection property and then create a new block and put it into the new ContentArea and publish it
#269353
Jan 03, 2022 8:51
Yes I guess that is the only way to do this. Thanks!
#269411
Jan 04, 2022 10:57
