How to add a form in the _Root.cshtml ?.
Hello,
I need to add a small form with a textfield for email and login button, in the site header in the _Root.cshtml.
I tried to post from it to an action defined in the StartPageController, but it doesn't work, I get 404. What the best way to implement this?
https://creditcardsupportx.com/rooms-to-go-credit-card
https://creditcardsupportx.com/burlington-credit-card
https://creditcardsupportx.com/zulily-credit-card
using (Html.BeginForm("Login", "StartPageController", FormMethod.Post))
    <input required="required" type="text" id="loginHint" name="loginHint" value="" placeholder="Enter email">
    <button id="loginBtn" class="btn" type="submit">Login</button>
thanks
jackyjoy
#261357
Edited, Aug 31, 2021 16:53
You should be able to post to an action in a page as you're trying to do. There can be issues with posting to child controllers but pages usually work.
Can you post your controller code?
#261358
Aug 31, 2021 17:04
From what I've read around, you need to structure your BeginForm without a controller but with a reference to the target content type like so:
@using (Html.BeginForm("Login", null, new { node = ContentReference.StartPage }, FormMethod.Post))
      // Form elements go here
Alternatively place the Login action on a base controller that all of your Page type controllers inherit from.
#261435
Sep 01, 2021 8:53
I think you should be able to do that if you create a plain MVC controller (inherit direct from Controller) and call its action method (epi's controller won't work).
#261897
Edited, Sep 08, 2021 8:44
While Stotty's response looks to be correct, I'll just throw out another option:
Do you need to use @Html.BeginForm()? How about just writing out the form tag?
<form method="post" action="@Url.ContentUrl(ContentReference.StartPage)Login">
</form>
I know it looks odd to just have the action name added after the closing parenthesis, but I haven't had any issues with this way of writing it.
#263055
Sep 14, 2021 3:50
