You can get the full IContent instance for each item either by fetching the items individually like this:
var items = myPage.MyContentArea.Items.Select(x => x.GetContent());
or by fetching them in bulk using IContentLoader like this:
var loader = ServiceLocator.Current.GetInstance<IContentLoader>();
var contentRefs = myPage.MyContentArea.Items.Select(x => x.ContentLink);
var items = loader.GetItems(contentRefs, currentPage.Language);
To compare versions, you can do that directly in the CMS UI by clicking the compare button (
) or you can access previous versions of a content item programmatically using the IContentVersionRepository, for example:
var versionRepo = ServiceLocator.Current.GetInstance<IContentVersionRepository>();
var versions = versionRepo.List(myPage.ContentLink, myPage.Language.Name);
Hello everyone,
I have started from Alloy project sample and need to know the following:
I have tried to understand this by using "ServiceLocator.Current.GetInstance<IContentRepository>()" and then using Linq to get the contentItems but not able to got all of the block details. (Like Id,Name etc..)
Please help me to know about this as i need to track the total no of blocks and then which one gets removed so that i can keep the block data where i need to keep it for further uses.
