Need help to understand the profiling details from MiniProfiler profiling tool.
Hello,
We are using MiniProfiler for one of the slow running page in our website which uses EPiServer Find service to get result to display on page and here is profiling detail in local environment.
What does it mean if it takes more time for URL, is it some EPiServer modules that are taking more time to process?
Deepa
#255865
Jun 01, 2021 6:32
Hi Deepa,
Are you using any third-party image optimization/cropping module? If yes then maybe that module is taking the time.
#255869
Jun 01, 2021 7:12
- Jun 01, 2021 7:51
Hi Ravindra,
Yes we are using ImageProcessor version 2.9.1 to optimize image as per tech audit guidelines.
Ravindra S. Rathore - Jun 01, 2021 7:56
Ok. If possible disable that module then check or remove the image rendering code and give it a try whether it improves the performance or not
- Jun 01, 2021 10:48
Yes I will try out this, thank you for guiding on this.
If you can reproduce locally, you can (and should) use a more powerful profiler, such as dotTrace, to look into details. I think the slowness might come from Find requests (uncached/multiple requests etc.), but that is yet to be seen.
#255871
Jun 01, 2021 7:28
- Jun 01, 2021 7:53
We did audit our website in Azure application insight to find out this page being slow and used dotTrace prior to this for profiling and it doesn't give any useful detail.
This result is from local environment and line ArticleSearchResult is where we have Find Request (GetContentResult()) with caching parameter passed to fetch the article result.
That is strange. Using dotTrace usually gives me the most comprehensive information. Application Insights profiler is good too, but it needs more experience to understand (basically an ETL so it contains a lot of information that can be overwhelming at first)
#255877
Jun 01, 2021 8:00
This is one of the sample for same page from dotTrace and as per your comments may be I am not able to make out of it and it shows more time for Native codes.
#255891
Jun 01, 2021 10:47
#255892
Jun 01, 2021 10:47
Try to expand thread #8 -ProcessRequestNotification.
Note that you can always reach out to developer support service for assistance
#255896
Jun 01, 2021 11:54
- Jun 02, 2021 5:50
Thank you.
Can you please help us with tutorial links which is helpful to get more understanding on dotTrace sampling results.
- Jun 02, 2021 7:57
I don't have something like that, unfortunately.
