Searching forms in the asset panel gives block results?
I have the Forms tab activated in the asset panel but when I do a search for forms I get a result with blocks.
The reqest looks like this:
http://localhost:6904/EPiServer/cms/Stores/contentstructure/?queryText=med&query=searchcontent&allLanguages=true&contentSearchAreas=CMS%2Fblocks&searchRoots=3%2C264872&maxResults=1000&filterDeleted=true
where search areas is "CMS%2Fblocks" so I guess that the result is correct according to the request.
Is this a bug or a configuration miss?
Thanks!
/Kristoffer
#254958
May 17, 2021 9:04
I just verified the exact same behavior in the Foundation platform so I guess this is a bug. Could you please confirm?
Thanks!
/Kristoffer
#255033
May 18, 2021 6:52
Praful Jangid
I have noticed something similar. When I have activated the blocks tab, I can browse for the forms within that assets pan.
Probably this is a bug (what you mentioned in your statement). Epi/optimizely can confirm on that too :)
#255107
May 19, 2021 13:15
Thanks Praful, then we will wait for Epi to fix it.
/Kristoffer
#255108
May 19, 2021 13:18
Hello,
Please register a developer support incident here: https://world.episerver.com/support/
If the issue can be replicated when running the latest version, then it should be accepted through triage and investigated.
#255112
May 19, 2021 16:06
If the issue can be replicated then a bug will be filed.
#255113
May 19, 2021 16:06
#255114
May 19, 2021 16:07
Bug filed!
/Kristoffer
#255876
Jun 01, 2021 8:00
