PAAS portal log streaming configuration
I am trying to configure logging in my EPI application so I can view logs in the PAAS portal log streams.  I have searched the forums and cannot find documentation on how this must be configured to work there.  I have a log statement according to this documentation:  https://world.episerver.com/documentation/developer-guides/CMS/logging/
I have the default EPiServerLog.config file in my project which is logging files locally but not in the PAAS portal log stream.  I'm hoping to see server errors with stack traces.
Thanks.
#253084
Apr 12, 2021 21:53
Scott Reed
On DXP The best way to see errors and information is Application Insights as that covers a lot more information such as stack traces and profiles. As far as logs  on the PASS portal goes Episerver automatically sets the TraceLoggerFactory which should output any logging information. This should be setup but you can find more info here https://world.episerver.com/documentation/developer-guides/digital-experience-platform/development-considerations/logging/. If you think there are configuration issues on your DXP instance I'd raise a ticket through Episerver support
#253151
Edited, Apr 13, 2021 13:59
