I think there are a few potential causes here. If the issue only occurred when you enabled content compression then I think the most likely cause might be caching as, in order to enable compression, you need to enable caching. If the login page is being cached, so will the anti-forgery token included within it which would cause the error you're getting on submission of the login form. If this is the issue, you'll need to prevent the login page (and probably several others) from being cached either by sending the appropriate cache-control headers or by setting up a different route in Azure Front Door which doesn't have caching/compression enabled.
Hi -
We've recently enabled file compression settings in Azure Front Door. The resources I've checked (.css, .js) are compressed correctly but we also find that's it's no longer possible to log in. It's possible to navigate to the login page, and enter your credentials, but when you click 'Log In' our custom error page is shown with the following error logged (below). The .EPiServerLogin cookie is not created either.
Has anyone encountered a similar problem or able to suggest what might be causing the issue?
