Dragging a block into TinyMCE, make the block smaller?
We  are using Episerver CMS 11.13.2.0
When a user drags a block into the editor, it takes up a whole line/row. Is there a way to make the block smaller so that when adding content before/after the block it looks more WYSIWYG? I recently incorporated changes that make the block not have forced <p> tages so that the block can be inline with content but when using the editor, what's there and what the results will be are off.
#248653
Feb 15, 2021 14:39
Praful Jangid
In that case, you can you the template feature. See below links
https://davidboland.site/blog/create-episerver-tinymce-default-templates
template allows you to add a structured markup. Then you can add a column structure markup and there you can add (drag & drop) your block in any column.
#248767
Feb 17, 2021 9:30
