ViewConfiguration Name is no longer translated
I have upgraded our plugin to CMS 12 and the followinmg added menu option does no longer get translated it is alway the same language no matter what UI language I select.
[ServiceConfiguration(typeof(ViewConfiguration))]
public class SendToTranslationView : ViewConfiguration<IContentData>
    public SendToTranslationView()
        var localization = ServiceLocator.Current.GetInstance<LocalizationService>();
        var currentCulture = Thread.CurrentThread.CurrentUICulture;
        Key = "SendToTranslationView";
        Name = localization.GetString("/Translations/ContentView/Heading");
        Description = localization.GetString("/Translations/ContentView/Description");
        ControllerType = "epi-cms/widget/IFrameController";
        ViewType = "/MyPlugin/ContentTranslationHistory/Index";
        IconClass = "epi-iconCatalog epi-icon--medium";
On startup currentCulture is sv-SE but after login the above code is run again and then with en as currentCulture.
It worked just fine in CMS 11, has the ViewConfiguration changed in CMS 12?
Thanks!
/Kristoffer
#269199
Edited, Dec 30, 2021 12:04
Looks like posting forum threads is the way to solve problems.
Name and Description no longer work but LanguagePath does, so this is the solution:
        LanguagePath = "/Translations/ContentView";
/Kristoffer
#269200
Dec 30, 2021 12:21
