Is there a way to use UIHints to specify display attributes?
I have a case where I cant edit the existing code for a content type, so I am adding properties programmatically. Since there is no code, is there a way to use the UIHint feature to specify features like SelectionOne or SelectMany on a property to show a dropdown?
#268070
Dec 08, 2021 20:12
Hi Jason,
Not sure if I understand your question correctly.
You are creating properties using code, correct?
If so why not just use a selection factory to populate the dropdown and then apply a selectmany or selectone attribute?
Paul
#268269
Dec 12, 2021 7:59
