How to get instance of PropertyData from PropertyInfo
I want to see if a property is personalized or not in an override method of PropertyFor.
In this override method I get an expression, and from that and can extract the PropertyInfo object for the property.
How do I get the PropertyData from the PropertyInfo object?
When I have the PropertyData object I want to cast it to a IPersonalizedRoles so I can see if it is personalized.
#268282
Dec 12, 2021 13:15
Hi Hannes,
The way I would do this is to maybe extend or create a method that allows you to pass in IContent (page or block) and a property name.
Then you should be able to use content.Property["PropertyNameHere"];
This is a quick example plucked from Alloy
var startPage = _contentLoader.Get<StartPage>(SiteDefinition.Current.StartPage);
var property = startPage.Property["MainContentArea"];
#268751
Dec 21, 2021 12:18
Yes, that was the way I had to go. Getting the PropertyData only from the PropertyInfo object was impossible.
#269114
Dec 28, 2021 8:42
