Selectionfactory (selectmany) does not work in secondary language.
When creating an editordescriptor that contains a selection-factory entry, the editordescriptor does not work for the secondary language on my site. The selection factory looks like this and works fine in my primary language and I am able to get the values in the views.
This is how it looks in the edit-view
Primary language:
Secondary language i get no possibility to add an entry:
I have identified it as an selectionfactory issue, because when I remove the property that uses selection factory it does work in all languages as expected. Is this a known bug or am I doing something wrong here?
#266116
Nov 02, 2021 10:33
- Nov 03, 2021 19:49
If you open the browser's developer tools, do you see any errors in the console?
Anders.cap - Nov 17, 2021 7:31
Yes, I am getting an error. Look below for screens
Yes I am getting a dojo error.
This more specifically.
I dont understand why this pops up in other languages then my primary language. I also get a GET-error for the dojo-widget.
#266864
Edited, Nov 17, 2021 7:30
- Nov 17, 2021 16:36
You should still be able to see the actual error if you try to load the URL that's provided in the message.
Posting the result of the url that failed and caused 500 error.
  "name": null,
  "modelType": "myprojectname.Models.ViewModels.VideoViewModel",
  "showForEdit": true,
  "hideSurroundingHtml": false,
  "uiType": null,
  "uiPackage": null,
  "customEditorSettings": {},
  "layoutType": null,
  "initialValue": null,
  "displayName": null,
  "groupName": null,
  "displayOrder": 10000,
  "settings": {
    "label": null
  "overlaySettings": {},
  "additionalValues": {},
  "mappedProperties": [],
  "properties": [
      "name": "Url",
      "modelType": "System.String",
      "uiType": "dijit/form/ValidationTextBox",
      "uiPackage": null,
      "layoutType": null,
      "displayName": "Url",
      "groupName": null,
      "displayOrder": 1,
      "settings": {
        "label": "Url",
        "placeHolder": "Legg inn url til video"
      "properties": [],
      "groups": [],
      "selections": []
      "name": "Title",
      "uiPackage": null,
      "layoutType": null,
      "displayName": "Tittel",
      "groupName": null,
      "displayOrder": 2,
      "settings": {
        "label": "Tittel",
        "placeHolder": "Videotittel"
      "properties": [],
      "groups": [],
      "selections": []
      "name": "Description",
      "uiType": "epi/shell/widget/ValidationTextarea",
      "uiPackage": null,
      "layoutType": null,
      "displayName": "Beskrivelse",
      "groupName": null,
      "displayOrder": 3,
      "settings": {
        "label": "Beskrivelse",
        "placeHolder": "Videobeskrivelse"
      "properties": [],
      "groups": [],
      "selections": []
      "name": "Published",
      "modelType": "System.DateTime",
      "uiType": "epi/shell/widget/DateTimeSelectorDropDown",
      "uiPackage": null,
        "converter": "epi.cms.propertydate"
      "layoutType": null,
      "displayName": "Publisert",
      "groupName": null,
      "displayOrder": 4,
      "settings": {
        "label": "Publisert",
        "required": true,
        "missingMessage": "The Publisert field is required."
      "properties": [],
      "groups": [],
      "selections": []
      "name": "ShowPublishedDate",
      "modelType": "System.Boolean",
      "uiType": "epi/shell/widget/CheckBox",
      "uiPackage": null,
      "layoutType": null,
      "displayName": "Vis publisert dato",
      "groupName": null,
      "displayOrder": 5,
      "settings": {
        "label": "Vis publisert dato",
        "required": true,
        "missingMessage": "The Vis publisert dato field is required."
      "properties": [],
      "groups": [],
      "selections": []
      "name": "TextForPublishedDate",
      "uiPackage": null,
      "layoutType": null,
      "displayName": "Tekst forann publisert dato",
      "groupName": null,
      "displayOrder": 6,
      "settings": {
        "label": "Tekst forann publisert dato"
      "properties": [],
      "groups": [],
      "selections": []
      "name": "Tags",
      "uiType": "epi-cms/contentediting/editors/CheckBoxListEditor",
      "uiPackage": null,
      "layoutType": null,
      "displayName": "Tag språk",
      "groupName": null,
      "displayOrder": 7,
      "settings": {
        "label": "Tag språk"
      "properties": [],
      "groups": [],
      "selections": [
          "value": "sosial på nett",
          "text": "Sosial på nett"
          "value": "bokmål",
          "text": "Bokmål"
          "value": "barn",
          "text": "Barn"
  "groups": [],
  "selections": []
There is no direct error pasting the JSON-files. It still seems like there are properties set to required that are not actually set to required in the code.
#266936
Edited, Nov 18, 2021 13:14
