How to get the category name from block?
We tagging our blocks in episerver using the built in category.
problem is getting the category name so I can use it in the blocks view.
Tried the code below but it's saying GetCategory isn't available in the controller.
public class ParallaxNavigationBlockController : BlockController<ParallaxNavigationBlock>
    public override ActionResult Index(ParallaxNavigationBlock currentBlock)
        var model = new ParallaxNavigationViewModel
            Category = (currentBlock as ICategorizable).Category.GetCategories().FirstOrDefault()
        return PartialView(model);
// ViewModel
public class ParallaxNavigationViewModel
    public Category Category { get; set; }
// Extension method for categories
public static IEnumerable<Category> GetCategories(this CategoryList categoryList)
    CategoryRepository categoryRepository = ServiceLocator.Current.GetInstance<CategoryRepository>();
    return categoryList.Select(x => categoryRepository.Get(x));
#267016
Nov 19, 2021 4:14
Niamul - Nov 19, 2021 5:19
got it
First
  1. If you're only expecting 1 category there's no need to load them all to just get the first
  2. Inject the dependency if doing the logic in a controller
  3. The reason why your extension method GetCategories doesn't work is it needs to be in a separate static class
Although you don't need GetCategories I have rewritten including the GetCategories extension if you need it for the future
    private readonly CategoryRepository _categoryRepository;
    public ParallaxNavigationBlockController(CategoryRepository categoryRepository) // Injected in. The correct way
        _categoryRepository = categoryRepository;
        var firstCategory = (currentBlock as ICategorizable).Category.FirstOrDefault();
            Category = firstCategory > 0 ? _categoryRepository.Get(firstCategory) : null
// ViewModel
public static class Extensions // Needs to be in a static class
#267032
Nov 19, 2021 9:25
