The problem is solved.
It appeared that another property had a wrong type set in the database. This property was of type string in code but had propertyDefinitionID 30 assigned, which is XHtmlString. We manually changed this to 7 (LongString) in the database and restarted EPiServer.
This probleem is strange because of multiple reasons:
But hey, case closed :-)
Hello,
We are experiening a strange problem with some of or content pages when retrieving the content:
Our property is defined as:
A quick lookup in the database shows that the the property is indeed defined as an XHtml property:
Does anybody know why this error occurs?
Note: We recently upgraded 11.17 to 11.20, but it is not clear when these problems actually started, we only found out just now.
