This is what works for me:
<?xml version="1.0"?>
<module>
<!-- Define a location for storing dojo modules. The "path" value is relative to the ClientResources physical folder. The "name" value acts as an alias for that location. -->
<dojoModules>
<add name="app" path="Scripts" />
</dojoModules>
</module>
Then if you are using this for something like an editor descriptor, it would look like this:
ClientEditingClass = "app/Editors/MyEditor;
And the path to that dojo module would be at "/ClientResources/Scripts/Editors/MyEditor.js"
Thanks, that gave me a tip and with this settings it works:
<module>
<clientModule initializer="Testing/Initializer">
<moduleDependencies>
<add dependency="CMS" type="RunAfter" />
</moduleDependencies>
</clientModule>
<dojo>
<paths>
<add name="Testing" path="Scripts" />
</paths>
</dojo>
</module>
Just removed ClientResources from path. I think I tried that but probably not...
Thanks again!
/Kristoffer
I'm trying to load a Dojo module and my module.config looks like this:
In /ClientResource/Scripts I have a Initializer.js but the error I get is this:
GET http://localhost:6904/EPiServer/Shell/11.36.0/ClientResources/Testing/Initializer.js net::ERR_ABORTED 404 (Not Found)
My is Epi looking for the file under Episerver/Shell... and not under /ClientResources/Scripts?
Thanks!
/Kristoffer
