Hi Kristoffer,
I looked in the sourcecode for the EPiServer.Labs.BlockEnhancements and it looks like this is the correct name (if I understud you correctly)
epi.cms.publishmenu
-Sebastian
Now that is a great start. I guess I just need to find out what the pluginarea is called. I will try to look into BlockEnhancement code and see if I can find it.
I'm still curious if this is documented any where?
Thanks!
/Kristoffer
In this article:
https://world.episerver.com/blogs/Duong-Nguyen/Dates/2013/12/Custom-views-and-plugin-areas-in-EPiServer-75/
I read this:
"Also, you may want to add your view to some other places, for instance the Tool button under the Content Settings Header, or the Publish/Option menu."
Then in the example it is shown how to add an item in the Tools menu.
I am interested in the "Publish/Option menu". What is the PlugInAreas name for that and what command is used to register the provider?
I cannot find any documentation about this any where?
Thanks!
/Kristoffer
