Upgrade from CMS 10.10.4 to 11.20.3
After upgrading from cms 10.10.4 to 11.20.3, I am not able to upgrade episerver.forms.samples to 3.6.0 from 3.3.0.
The error which comes is as below:
Package 'EPiServer.Forms.Samples.3.6.0 : EPiServer.Forms [4.28.0, 5.0.0)' does not exist in project 'Aspect.Web'
But Episrevre.forms current version is 4.30.2.
Please suggest.
#247593
Edited, Jan 25, 2021 12:34
Are you using the Package Manager Console?
Then make sure you have the corrent project selected (in Default Project field/box), where you have Episerver.Forms module is already installed .
Again, check in Consolidate tab (in Manage Nuget Package for solution), if you have multiple versions of Episerver.Forms get installed. If yes then correct that.
EPiServer.Forms.Samples is dependent of Episerver.Forms, and mudule version mismatch (or installed multiple different version) may cause that issue. So, make sure you have same version installed in all the projects and also you have EPiserver.Forms installed in the project where you are trying to install/upgrade the Episerver.Forms.Sample
#247667
Jan 26, 2021 6:59
Thanks Praful for the information. The version of Episerver.forms installed is 4.30.2.0 and project has reference for the same.
An older version was there, which I removed from packages folder. Still getting below error:
Install failed. Rolling back...
Package 'EPiServer.Forms.Samples.3.7.0 : EPiServer.Forms [4.30.1, 5.0.0)' does not exist in project 'Aspect.Web'
Please suggest.
#248160
Feb 04, 2021 15:27
Try clearing nuget cache and then try to install again. Can you also paste here packages.config if solution not work.
#248162
Feb 04, 2021 16:00
<packages>
  <package id="BVN.404Handler" version="11.4.0" targetFramework="net48" />
  <package id="Castle.Core" version="4.4.1" targetFramework="net48" />
  <package id="Castle.Windsor" version="4.1.1" targetFramework="net48" />
  <package id="DotNetZip" version="1.10.1" targetFramework="net462" />
  <package id="elmah" version="1.2.2" targetFramework="net462" />
  <package id="Elmah.AzureTableStorage" version="1.0.0.0" targetFramework="net462" />
  <package id="elmah.corelibrary" version="1.2.2" targetFramework="net462" />
  <package id="Elmah.Mvc" version="2.1.2" targetFramework="net462" />
  <package id="EntityFramework" version="6.4.4" targetFramework="net48" />
  <package id="EPiServer.AddOns.Helpers" version="0.4.0.0" targetFramework="net48" />
  <package id="EPiServer.Azure" version="10.0.1" targetFramework="net48" />
  <package id="EPiServer.CMS" version="11.20.3" targetFramework="net48" />
  <package id="EPiServer.Cms.AddOns.Blocks" version="2.4.1" targetFramework="net48" />
  <package id="EPiServer.CMS.AspNet" version="11.20.3" targetFramework="net48" />
  <package id="EPiServer.CMS.Core" version="11.20.3" targetFramework="net48" />
  <package id="EPiServer.CMS.TinyMce" version="2.13.2" targetFramework="net48" />
  <package id="EPiServer.CMS.UI" version="11.32.1" targetFramework="net48" />
  <package id="EPiServer.CMS.UI.Core" version="11.32.1" targetFramework="net48" />
  <package id="EPiServer.Find" version="13.3.0" targetFramework="net48" />
  <package id="EPiServer.Find.Cms" version="13.3.0" targetFramework="net48" />
  <package id="EPiServer.Find.Framework" version="13.3.0" targetFramework="net48" />
  <package id="EPiServer.Forms" version="4.30.2" targetFramework="net48" />
  <package id="EPiServer.Forms.Core" version="4.30.2" targetFramework="net48" />
  <package id="EPiServer.Forms.Samples" version="3.3.0" targetFramework="net48" />
  <package id="EPiServer.Forms.UI" version="4.30.2" targetFramework="net48" />
  <package id="EPiServer.Framework" version="11.20.3" targetFramework="net48" />
  <package id="EPiServer.Framework.AspNet" version="11.20.3" targetFramework="net48" />
  <package id="EPiServer.Labs.LanguageManager" version="4.0.1" targetFramework="net48" />
  <package id="EPiServer.Logging.Log4Net" version="2.2.2" targetFramework="net48" />
  <package id="EPiServer.Marketing.KPI" version="2.5.4" targetFramework="net48" />
  <package id="EPiServer.Marketing.Messaging" version="1.3.0" targetFramework="net48" />
  <package id="EPiServer.Marketing.Testing" version="2.6.5" targetFramework="net48" />
  <package id="EPiServer.Packaging" version="3.4.0" targetFramework="net48" />
  <package id="EPiServer.Packaging.UI" version="3.3.0" targetFramework="net462" />
  <package id="EPiServer.Search" version="9.0.3" targetFramework="net48" />
  <package id="EPiServer.ServiceLocation.StructureMap" version="2.0.3" targetFramework="net48" />
  <package id="EPiServer.TinyMCESpellChecker" version="2.0.0" targetFramework="net48" />
  <package id="EPiServer.VisitorGroupsCriteriaPack" version="2.0.1" targetFramework="net48" />
  <package id="EPiServer.XForms" version="1.0.3" targetFramework="net48" />
  <package id="Geta.404Handler" version="1.2.1" targetFramework="net48" />
  <package id="lodash.TypeScript.DefinitelyTyped" version="2.4.9" targetFramework="net462" />
  <package id="log4net" version="2.0.8" targetFramework="net462" />
  <package id="Lucene.Net" version="3.0.3" targetFramework="net48" />
  <package id="Microsoft.AspNet.Mvc" version="5.2.7" targetFramework="net48" />
  <package id="Microsoft.AspNet.Providers.Core" version="2.0.0" targetFramework="net462" />
  <package id="Microsoft.AspNet.Razor" version="3.2.7" targetFramework="net48" />
  <package id="Microsoft.AspNet.WebApi" version="5.2.3" targetFramework="net462" />
  <package id="Microsoft.AspNet.WebApi.Client" version="5.2.3" targetFramework="net462" />
  <package id="Microsoft.AspNet.WebApi.Core" version="5.2.3" targetFramework="net462" />
  <package id="Microsoft.AspNet.WebApi.WebHost" version="5.2.3" targetFramework="net462" />
  <package id="Microsoft.AspNet.WebPages" version="3.2.7" targetFramework="net48" />
  <package id="Microsoft.Azure.KeyVault.Core" version="1.0.0" targetFramework="net462" />
  <package id="Microsoft.Azure.Services.AppAuthentication" version="1.6.0" targetFramework="net48" />
  <package id="Microsoft.Data.Edm" version="5.6.4" targetFramework="net45" />
  <package id="Microsoft.Data.OData" version="5.6.4" targetFramework="net45" />
  <package id="Microsoft.Data.Services.Client" version="5.6.4" targetFramework="net45" />
  <package id="Microsoft.IdentityModel.Clients.ActiveDirectory" version="5.2.8" targetFramework="net48" />
  <package id="Microsoft.IdentityModel.JsonWebTokens" version="6.8.0" targetFramework="net48" />
  <package id="Microsoft.IdentityModel.Logging" version="6.8.0" targetFramework="net48" />
  <package id="Microsoft.IdentityModel.Tokens" version="6.8.0" targetFramework="net48" />
  <package id="Microsoft.Net.Compilers" version="2.2.0" targetFramework="net462" developmentDependency="true" />
  <package id="Microsoft.Net.Http" version="2.0.20710.0" targetFramework="net45" />
  <package id="Microsoft.Rest.ClientRuntime" version="2.3.22" targetFramework="net48" />
  <package id="Microsoft.Tpl.Dataflow" version="4.5.24" targetFramework="net462" />
  <package id="Microsoft.Web.Infrastructure" version="1.0.0.0" targetFramework="net462" />
  <package id="Microsoft.Web.Xdt" version="2.1.1" targetFramework="net462" />
  <package id="Microsoft.WindowsAzure.ConfigurationManager" version="3.1.0" targetFramework="net462" />
  <package id="Mogul.SEO.Manager.Package" version="5.2.5.0" targetFramework="net48" />
  <package id="Newtonsoft.Json" version="12.0.3" targetFramework="net48" />
  <package id="NHunspell" version="1.2.5359.26126" targetFramework="net462" />
  <package id="NuGet.Core" version="2.7.2" targetFramework="net462" />
  <package id="React.TypeScript.DefinitelyTyped" version="0.1.12" targetFramework="net462" />
  <package id="SharpZipLib" version="0.86.0" targetFramework="net462" />
  <package id="StructureMap" version="4.7.1" targetFramework="net48" />
  <package id="structuremap.web" version="4.0.0.315" targetFramework="net48" />
  <package id="structuremap.web-signed" version="3.1.6.191" targetFramework="net462" />
  <package id="structuremap-signed" version="3.1.9.463" targetFramework="net462" />
  <package id="System.ComponentModel.Annotations" version="4.7.0" targetFramework="net48" />
  <package id="System.Data.SqlClient" version="4.8.2" targetFramework="net48" />
  <package id="System.IdentityModel.Tokens.Jwt" version="6.8.0" targetFramework="net48" />
  <package id="System.IO" version="4.3.0" targetFramework="net48" />
  <package id="System.Net.Http" version="4.3.4" targetFramework="net48" />
  <package id="System.Reflection.Emit" version="4.7.0" targetFramework="net48" />
  <package id="System.Reflection.Emit.Lightweight" version="4.3.0" targetFramework="net462" />
  <package id="System.Runtime" version="4.3.1" targetFramework="net48" />
  <package id="System.Security.AccessControl" version="4.7.0" targetFramework="net48" />
  <package id="System.Security.Cryptography.Algorithms" version="4.3.1" targetFramework="net48" />
  <package id="System.Security.Cryptography.Encoding" version="4.3.0" targetFramework="net48" />
  <package id="System.Security.Cryptography.Primitives" version="4.3.0" targetFramework="net48" />
  <package id="System.Security.Cryptography.X509Certificates" version="4.3.2" targetFramework="net48" />
  <package id="System.Security.Cryptography.Xml" version="4.7.0" targetFramework="net48" />
  <package id="System.Security.Permissions" version="4.7.0" targetFramework="net48" />
  <package id="System.Security.Principal.Windows" version="4.7.0" targetFramework="net48" />
  <package id="System.Spatial" version="5.6.4" targetFramework="net45" />
  <package id="System.Threading.AccessControl" version="4.7.0" targetFramework="net48" />
  <package id="System.ValueTuple" version="4.5.0" targetFramework="net48" />
  <package id="WindowsAzure.ServiceBus" version="6.0.3" targetFramework="net48" />
  <package id="WindowsAzure.Storage" version="9.3.3" targetFramework="net48" />
</packages>
#248163
Feb 04, 2021 16:08
