Property list not being able to save/publish
CMS 11.14.2
Ive implemented an IList<MenuItem> but it is not triggering the "Save/publish" button on change/add, what am I missing?
Ive implemented the necessary items i think:
[Display(Order = 340, GroupName = TabNames.Menu)]
[EditorDescriptor(EditorDescriptorType = typeof(CollectionEditorDescriptor<MenuItem>))]
public virtual IList<MenuItem> TopBannerMenu { get; set; }
[PropertyDefinitionTypePlugIn]
public class MenuItemListProperty : PropertyListBase<MenuItem>
public class PropertyListBase<T> : PropertyList<T>
        private readonly IObjectSerializer _objectSerializer;
        private Injected<ObjectSerializerFactory> _objectSerializerFactory;
        public PropertyListBase()
            _objectSerializer = _objectSerializerFactory.Service.GetSerializer("application/json");
        protected override T ParseItem(string value)
            return _objectSerializer.Deserialize<T>(value);
No javascript error in console, other property lists in solution are working.
#227300
Edited, Sep 01, 2020 8:13
Have you tried without using a custom PropertyListBase<>? Shouldn't need that anymore. Probably some issue with json serialization...
public class MenuItemListProperty : PropertyList<MenuItem> { }
What does MenuItem contain? Any suspect url properties?
#227301
Sep 01, 2020 8:23
Hej Daniel,
hmm without it i get
Type 'System.Collections.Generic.IList`1[[Shared.MenuItem, x.Site, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null]]' could not be mapped to a PropertyDefinitionType
        public string Title { get; set; }
        public bool CssBold { get; set; }
        public bool CssCampaign { get; set; }
This is locally for now. I have tested with Url and removed it for test. Ive seen solution with UrlConverter if I were to use Url.
#227302
Sep 01, 2020 8:48
Hi, Daniel is right about the base class.
I just copied your code into an Alloy site, and made some small adjustments.
My example menu class:
    public string Url { get; set; }
The property definition:
[PropertyDefinitionTypePlugIn(
    DisplayName = "Menu list property",
    GUID = "28B811BE-9551-4F73-A86E-584044432B66")]
[Serializable]
I like adding a name and guid to my property definitions. Why: https://www.gulla.net/episerver-and-renaming-a-custom-property/
I also added the Serializable-attribute.
Then add a property to ArticlePage:
[Display(Order = 340, GroupName = "Menu")]
It worked for me in an Alloy site running 11.18.0 (I know that version were delisted).
If it still does not work, I would enter admin mide, click «Config», «Edit custom property types», then delete your property definition and restart the site.
#227372
Edited, Sep 02, 2020 11:45
thx Thomas, I changed to
and removed the property, restarted, and i works!
Thanks ;)
#227376
Sep 02, 2020 12:47
