Does anyone have any ideas on this? Any help would be much appreciated. 🙂
Hi valdis, thanks for responding. Yes, this issue occurs no matter where the focal point is placed. It's basically a matter of the crops differing when there is a focal point (red) or when there is no focal point (grey). Adding a focal point should not result in the requested crop dimensions being inaccurate, IMO.
I'm going to give this one last try, any more thoughts from anyone? Sorry for bumping the thread again.
I was going to look at this later this week. But there is always a chance for you to spin off source code for the plugins and help hammering out the bugs! :)
I am using EPiServer version 11.14.1.0, with the ImageResizing module installed alongside EPiFocalPoint (both the latest versions). We're experiencing an issue where when we attempt to crop images with a querystring (e.g.
?mode=crop&width=1280&height=720), that the crop result differs when the image has a focal point set and when it doesn't have a focal point set. This is the case for all images we upload.For example, we have an image with an original resolution of 1136 x 773. After applying the above querystring to this image without adding a focal point to it using the EPiFocalPoint plug-in, the resulting cropped image has a resolution of 1136 x 720 which is correct (seeing as the image isn't stretched to 1280 pixels in width). However, after saving a focal point to the image in the CMS, the resulting cropped image has a resolution of 1136 x 639.
Has anyone else experienced this issue before? And if so, are there any known solutions? I want the two results to be consistent with one another. The result of this not being the case is that e.g. sliders on several pages are displaying images in different heights when some have focal points set and others do not. Obviously, we would prefer the images to always have the height we set in the querystring, without having to resort to forcing this in CSS.
