Creating default values for properties on pages
Hi.
I already know of SetDefaultValues on PageData, but as far as I know this only executes when the page instance is created.
Is there a way to set default properties on a page that already exists? And only if the property is NULL?
#228324
Edited, Sep 23, 2020 13:08
- Sep 24, 2020 4:53
I don't see how this will help since I only need it to run once and at startup.
So if I use IInitializableModule maybe and get the items.
Ravindra S. Rathore - Sep 25, 2020 7:09
Hi Carl S, The content event will trigger when you publish/create/delete the content so you can check your NULL condition there
- Sep 25, 2020 7:13
Hi Ravindra S. Rathore, Yep I know. But as I wrote before. I need it to be created at startup. Cannot wait for the user to publish the item.
Ravindra S. Rathore - Sep 25, 2020 7:55
Use the CreatingContent or CreatedContent based on your need.
https://marisks.net/2017/01/22/episerver-content-events-explained/
You can create a scheduled job, or an admin tool that will:
  • Get all pages of a specific type
  • For every page
    • Check if the property is null
      • Create writable clone of the page
      • Update property
      • Save
Or, lets say your property is of type string, and you want to set it's default value some time after adding it.
You could probably do:
[PropertyDefinitionTypePlugIn]
public class PropertyStringWithDefaultHackValue : PropertyString
     public override object Value => base.Value ?? "Hack";
And then change your property on your content type to:
[Display(Name = "This should work")]
[BackingType(typeof(PropertyStringWithDefaultHackValue))]
public virtual string MyString { get; set; }
#228332
Edited, Sep 23, 2020 15:17
- Sep 24, 2020 4:55
It is not a string, it's a custom property type, IList<..> and this contains a IList<...>.
I'll try a IInitializableModule and see if I can solve it that way.
- Sep 24, 2020 5:30
I think this worked even with an IList<...> have to test it further.
- Sep 24, 2020 5:30
Thanks for now.
- Sep 25, 2020 6:58
Tomas Hensrud Gulla, your solution does not work for propertystring.. it worked for a IList for some reason.
Ok tried the IInitializableModule and get an exception:
The property XXX is read-only
How do I make it writable? There is no overload called "MakeWritable" or something as far as I can see.
Note! This is a IList that I try to initiate from null in this instance.
#228362
Edited, Sep 24, 2020 5:16
Tomas Hensrud Gulla - Sep 25, 2020 7:51
CreateWritableClone() og the PageData object.
What Tomas suggested does not work. At least not in a already custom property type. Any other ideas?
public class CustomInnerProperty
     [Display(Order = 900, Name = "Id")]
     [BackingType(typeof(StringAsGuidDescriptor))]
     public virtual string Id { get; set; } = Guid.NewGuid().ToString();
public class StringAsGuidDescriptor : PropertyString
       get => string.IsNullOrEmpty(base.String) ? Guid.NewGuid().ToString() : base.String;
       set => SetPropertyValue(value, () => base.String = value?.ToString());
public class CustomInnerPropertyDescriptor : CollectionEditorDescriptor<CustomInnerProperty>
   public CustomInnerPropertyDescriptor()
      GridDefinition.DisableDndSorting = true;
public class CustomOuterProperty
   [Required]
   [Display(Order = 100, Name = "Items")]
   [EditorDescriptor(EditorDescriptorType = typeof(CustomInnerPropertyDescriptor))]
   public virtual IList<CustomInnerProperty> Items { get; set; }
#228512
Sep 28, 2020 12:13
