Blocks are not rendered on server, only in local environment
Hi.
Has a website based on CMS and Commerce.
Via Visual Studio it works as intended, but after a Publish and then uploaded to a Windows Server with IIS, there will be problems.
Almost all Blocks are not rendered out, there are only empty <div>.
Any suggestions on why this might be the case?
Do you need to see any code?
Latest CMS and Commerce, Windows Server 2019 with IIS 10.
#228001
Sep 17, 2020 13:29
Ravindra S. Rathore
Any errors in logs?
And which publishing profile you are using while publishing the code?
#228002
Sep 17, 2020 13:58
Tomas Hensrud Gulla
Same database in both environments?
Or different (empty) database after publish?
#228006
Sep 17, 2020 14:39
As a thought, have you checked to see whether the .cshtml views for the missing blocks are in the published site? Generally where I've seen problems like this where something appears locally but not when published, it's come down to files not being published.
It may also be useful to set up a local site pointed to the published version so you can establish whether it's an issue with the server or the publish.
#228046
Sep 18, 2020 7:32
