Add Favicon in CMS mode (Episerver 9)
JJ
JJ
Is it possible to add Favicon in CMS mode in Episerver 9?
I found this answer https://world.episerver.com/forum/developer-forum/-Episerver-75-CMS/Thread-Container/2019/2/favicon-in-edit--admin-mode/ but it shows how to replace an existing favicon.
In our case there is no favicon displayed at all.
Thanks.
#227140
Aug 28, 2020 9:53
Manoj Kumawat
I believe you should be able to find the favicon under below library when you unzip CMS.zip module.
It has a favicon icon there. Have you deployed your solution to IIS port or running it through VS only?
#227160
Aug 28, 2020 13:59
JJ
Thank you for your suggestion. It's deployed and running in IIS but I also run it through VS when debugging.
That CMS.zip folder didn't contain favicon.ico file.
Adding favicon.ico file to the CMS.zip didn't help either - it didn't appear in the CMS.
#227326
Sep 01, 2020 14:21
Manoj Kumawat
JJ, You will need to republish your solution if you are running a deployed solution. That will update your published directory in place. It sometimes takes some time to load the Favicon icon. Let me know if you still can't figure it out.
#227377
Sep 02, 2020 13:10
