How to provide headings in between a set of properties?
I want to provide headings for a set of properties present in a single tab.
How to do that?
#224148
Jun 12, 2020 9:23
If grouped properties are to be used in a single tab i would advise using Local Blocks for achieving this, and than using the local block in your Page or Block Model.
e.g.
    [ContentType(DisplayName = "Meta Data Block",
        AvailableInEditMode = false)]
    public class MetaDataBlock : BlockData
    [ContentType(
        DisplayName = "Home Page",
        Description = "Site Home Page",
    public class HomePage : SiteBasePage
        [Display(Name = "Meta Data", Order = 400)]
        public virtual MetaDataBlock MetaData {get;set;
#224152
Edited, Jun 12, 2020 9:43
If local blocks do not suit your needs, check out my blog post:
https://www.gulla.net/episerver-help-texts-improved/
These can be placed in-between other properties. You may customize this to look more like a heading if you like.
#224153
Jun 12, 2020 10:31
Tanvi - Jun 12, 2020 10:36
How to customize this? I dont want any tooltip text
The blog post shows step by step, how I created this.
There is no tooltip in the final result.
#224155
Jun 12, 2020 10:37
