How to extend Fileupload dialog with required description
I have a case where my customer needs to have required description on each image uploaded to episerver. We have extended ImageData and added a description field on this where the editor add the description if they remember. But how can we set the Description field required so that editors needs to add the description for each file. I think to extend the fileupload dialog will be the cleanes solution, but have not figured out how.
#224226
Jun 15, 2020 5:30
this might not be exactly what you are looking for but we have the same field "required" through validation when using it.
Create a validator using the IValidate interface, use it to validate content (this might be preformance heavy but it works fine on small-medium sites).
Something like this, Ex:
IEnumerable<ValidationError> IValidate<ContentData>.Validate(ContentData page)
            string errorMessageTemplate = @"Bilden med namn: ""{0}"" saknar beskrivning!";
            ValidationErrorSeverity severity = ValidationErrorSeverity.Error;
            List<ValidationError> errors = new List<ValidationError>();
            PropertyDataCollection pageProperties = page.Property;
            foreach (PropertyData propertyData in pageProperties)
                //Built-in properties that we want to ignore
                if (propertyData.OwnerTab == -1) continue;
                try
                    //ContentArea
                    if (propertyData.PropertyValueType == typeof(ContentArea))
                        var contentArea = (ContentArea)propertyData.Value;
                        if (contentArea.Items != null)
                            foreach (var item in contentArea.Items)
                                var content = item.GetContent();
                                if (content as ImageFile != null)
                                    if (string.IsNullOrEmpty(((ImageFile)content).Description))
                                        errors.Add(
                                            new ValidationError
                                                ErrorMessage = string.Format(errorMessageTemplate, ((ImageFile)content).Name),
                                                PropertyName = propertyData.Name,
                                                Severity = severity
                    //ContentReference
                    else if (propertyData.PropertyValueType == typeof(ContentReference))
                        var reference = propertyData.IsNull ? null : propertyData.Value as ContentReference;// page.GetValue(propertyData.Name) as ContentReference;
                        if (!ContentReference.IsNullOrEmpty(reference))
                            ImageFile file = null;
                            var locator = ServiceLocator.Current.GetInstance<IContentRepository>();
                            try
                                file = locator.Get<ImageFile>(reference);
                            catch (Exception)
                                file = null;
                            if (file != null)
                                if (string.IsNullOrEmpty(((ImageFile)file).Description))
                                    errors.Add(
                                            new ValidationError
                                                ErrorMessage = string.Format(errorMessageTemplate, file.Name),
                                                Severity = severity
                catch
                   //Handle
            return errors;
Should give you a view like this when trying to use an image without description:
#224255
Jun 15, 2020 12:16
- Jun 15, 2020 13:50
Not actually what I was looking for, but thank you for an alternative solution.
