How to check if there are elements in IList?
I want to put a validation on IList to check if there are elements added in the ILIst.
If no elements present, I wan to show a validation message saying "Please add values in the list".
public virtual IList<QuestionnaireAnswerBlock> Answers { get; set; }
Please help.
#224815
Jun 26, 2020 12:56
Ravindra S. Rathore
Hi Tanvi,
Make it required
[required]
And if you want to customize the validation message then create a custom validation attribute. The solution I mentioned in your other question
https://world.episerver.com/forum/developer-forum/-Episerver-75-CMS/Thread-Container/2020/6/how-to-limit-number-of-elements-in-ilist-with-only-minimum-elements-value/
#224818
Edited, Jun 26, 2020 13:30
As Ravindra suggested you can just use a required attribute.
Or, if you want to be able to valdiate a specific number of items, how about a validation attribute like this:
[AttributeUsage(AttributeTargets.Property)]
public class MinItemsAttribute : ValidationAttribute
	private readonly int _minAllowed;
	public MinItemsAttribute(int minAllowed)
		_minAllowed = minAllowed;
	protected override ValidationResult IsValid(object value, ValidationContext validationContext)
		var linkItemCollection = value as LinkItemCollection;
		if (linkItemCollection != null && ValidateMinAllowed(linkItemCollection.Count))
			return ValidationResult.Success;
		var contentArea = value as ContentArea;
		if (contentArea?.Items != null && ValidateMinAllowed(contentArea.Count))
		var enumerable = value as IEnumerable;
		if (enumerable != null && ValidateMinAllowed(enumerable.Cast<object>().Count()))
		return new ValidationResult(FormatErrorMessage(validationContext.DisplayName));
	private bool ValidateMinAllowed(int count)
		return count >= _minAllowed;
	public override string FormatErrorMessage(string name)
		return !string.IsNullOrEmpty(ErrorMessage) ? ErrorMessage : $"{name} requires at least {_minAllowed} items.";
It'll work on a Link Item Collection, Content Area or IList<>.
Using it is as simple as:
[MinItems(2)]
You can customize the error message as well:
[MinItems(2, ErrorMessage = "Please add at least 2 values to the list")]
#224819
Edited, Jun 26, 2020 14:15
