VideoFile (Video) Player
Hello all,
I have a VideoFile.cs model as well as it's View (Views/VideoFile/Index.cshtml), with a disabled download control on a player.
However when I upload video through TinyMCE -> Insert/edit media, it then uses some other than my player and has download control enabled.
How can I make it use my player which is in Views/VideoFile/Index.cshtml?
Also when TinyMCE -> Insert/edit media -> Advanced used, nothing is being inserted, why so?
Thank you, cheers!
#223399
May 27, 2020 11:06
Ravindra S. Rathore
Hi Ričardas,
Can you please share your VideoFile.cs and view file code here?
#223400
May 27, 2020 12:01
fuji - May 28, 2020 8:06
Hi Ravindra,
just pinging you since added requested files in separate post, thanks for your reply!
- May 28, 2020 8:40
I didn't found an error in your code files its something defiantly related with TinyMCE
fuji - May 28, 2020 8:50
Oh, ok, I guess it is, thanks anyway!
VideoFile.cs
using EPiServer.Core;
using EPiServer.DataAnnotations;
using EPiServer.Framework.DataAnnotations;
namespace Website.Web.Models.Media
    [ContentType(GUID = "85468104-E06F-47E5-A317-FC9B83D3CBA6")]
    [MediaDescriptor(ExtensionString = "flv,mp4,webm")]
    public class VideoFile : VideoData
View:
@model VideoFile
    string videoUrl = Url.ContentUrl(Model.ContentLink);
    string videoExtension = Path.GetExtension(videoUrl ).Replace(".", "");
<video controls controlsList="nodownload">
    <source src="@videoUrl " type="video/@videoExtension">
    Your browser does not support the video tag.
</video>
But I now guess I should cover this question more on TinyMCE side than VideoFile model, something as here https://www.tiny.cloud/docs/plugins/media/#audio_template_callback
#223412
May 27, 2020 15:13
What you could do is add a UI descriptor for your video file:
[UIDescriptorRegistration]
public class VideoFileDescriptor : UIDescriptor<VideoFile>, IEditorDropBehavior
	public EditorDropBehavior EditorDropBehaviour
		get;
		set;
	public VideoFileDescriptor()
		EditorDropBehaviour = EditorDropBehavior.CreateContentBlock;
This means that when an editor drag-and-drops in from the assets pane it won't create a link (the default) but will instead insert it as content—which will use your view.
I think that'd be the easiest way to solve this and get the behaviour you want here.
#223746
Edited, Jun 03, 2020 14:46
