Unable to upload video files
Hello.
I'm having trouble uploading video files.
Has the following code:
    [ContentType(GUID = "1f7218e9-bddf-4734-b067-4d2d68b5dade")]
    [MediaDescriptor(ExtensionString = "mp4,webm,ogg,mov")]
    public class VideoMediaData : VideoData
        [CultureSpecific]
        [Display(
            Name = "Name",
            Description = "Name of the video file",
            Order = 10)]
        public virtual string VideoName { get; set; }
Have no problems uploading images and for example PDF files with similar solution.
Error messages I get when uploading video files are:
Object reference not set to an instance of an object.
Any thoughts on why it doesn't work and maybe some suggestion on some solution I can try?
#223114
May 19, 2020 8:51
It might have something to do with the size of the video, by default only 4MB files can be accepted by ASP.NET. Can you get the full error message/stacktrace ?
#223117
May 19, 2020 12:28
I use two video files for testing, one .mp4 file that has 375 kb in size, the other file is a .webm of 2.07 mb.
Same error for both files.
Can upload images larger than 4 mb without problems.
If I check the network tab in Chrome Developer Tools, I get this JSON response:
[{"index":0,"fileName":"small.mp4","errorMessage":"Object reference not set to an instance of an object.","contentLink":null}]
Nothing is logged in the log file.
No stack trace,
Error message appears in the file upload box, so it will not be a total crash of site.
Cannot share link to an image for any reason.
#223118
Edited, May 19, 2020 12:38
I used same code in the Alloy demo site it works fine for me and able to upload more than 4MB size file. You can try with below settings.
 <system.webServer>
    <security>
      <requestFiltering>
        <requestLimits maxAllowedContentLength="1073741824" />
      </requestFiltering>
    </security>
  </system.webServer>
  <location path="EPiServer">
    <system.web>
      <httpRuntime maxRequestLength="1048576" requestValidationMode="2.0" executionTimeout="7200" />
    </system.web>
  </location>
#223131
May 19, 2020 18:46
Ravindra S. Rathore
Hi Ompa
Are you able to see your VideoMediaData inside "Media Type" in CMS->Admin->Content Type?
Can you try renaming this "VideoMediaData" class with some other name and give a try?
#223151
Edited, May 20, 2020 6:37
Hello.
Have added these lines to Web.config, but it remains the same problem.
I have created an empty CMS site and there is also a Commerce installed. Installed according to the documentation.
So is it something I miss, something that Alloy comes with but that doesn't come with an empty CMS installation?
I see VideoMediaData under MediaTypes. The other media types are also there.
#223152
May 20, 2020 7:01
- May 20, 2020 7:07
Hi.
Deleted the class completely, created it again with a new name, and now it works.
Thank you all for your help!
#223154
May 20, 2020 7:34
- May 20, 2020 7:40
Great !!! I also updated my above comment answer in a thread
