Publish button does not display when adding SEO keywords
We loaded the newest version of Episerver into our development environment and testing everything.  We found that when we add keywords in SEO the publish button does not appear.  Is anyone else having this issue?
#221635
Apr 22, 2020 16:04
Minesh Shah (Netcel)
I have just tested this and could not replicate just to confirm i was on version 11.15.0 of Episerver
My test property was as follows
       public virtual IList<string> StringPropertyList { get; set; }
#221640
Apr 22, 2020 17:51
your image shows you on the Content tab.  I am on the SEO tab.
#221641
Apr 22, 2020 17:56
This was an Alloy solution I installed from scratch, which does not use a Property List for their keywords property, so i ahd to make a new one as an example.
Can you show me the property type for your SEO Keywords via code ?
#221643
Apr 22, 2020 18:02
Also if you navigate to admin mode what is your SEO Keywords property showing as here
#221645
Apr 22, 2020 18:05
