How do I stop ampersand replacing with &
Here am trying to embedd youtube video in some page using tiny mce editor and url contians & symbols.
when i publish the page and view in browser the & is replacing with & symbols. its bracking our functionality.
i dont want to replace & with &.
#221604
Edited, Apr 22, 2020 6:57
Ravindra S. Rathore
I think you can try changing the entity_encoding to raw
entity_encoding : "raw"
Try can you please try this-
[ModuleDependency(typeof(TinyMceInitialization))]
    public class ExtendedTinyMceInitialization : IConfigurableModule
            context.Services.Configure<TinyMceConfiguration>(config =>
                // Add content CSS to the default settings.
                config.Default()
                    .ContentCss("/static/css/editor.css")
                    // global config to use numeric encoding, see last line if you only need
                    // it for one property on a type
                    .AddSetting("entity_encoding", "raw");
                // add settings to tinymce
                config.Default()
                    .AddPlugin("code charmap")
                    .AppendToolbar("code charmap");
                // OR use numeric encoding only for a specific types field
                config.For<StandardPage>(t => t.SpecialField).AddSetting("entity_encoding", "raw");
#221606
Apr 22, 2020 7:39
Hi Ravindra,
Thanks for your reply. here my editior is in block. when i apply this one entity_encoding : "raw"  , am facing problems for other options.
like its not displaying code icon and other icons.
.image  u can see the image here
https://drive.google.com/open?id=1ZifTJnh8gmIQoXx3J7rLlNvwFvIXTiae
here is my code
config.Default()
.AddSetting("valid_children", "+body[style]").AddSetting("extended_valid_elements", "script[language|type|src]").AddSetting("extended_valid_elements", "select[onchange|class|id],a[class|id|aria-label|href|name|rel|rev|urn|title|target|methods|hreflang|media|shape|type|class],div[data-experience]")
.RawSettings(customSettings);
config.For<EditorBlock>(t => t.MainBody).AddSetting("entity_encoding", "raw");
#221636
Edited, Apr 22, 2020 16:04
Ravindra S. Rathore
You can add them by .AddPlugin("code other buttons") method.
#221638
Edited, Apr 22, 2020 16:10
Ravindra S. Rathore
One more thing did the encoding resolved your "&amp;" issue?
#221677
Apr 23, 2020 6:34
sandeep vemula - Apr 23, 2020 11:03
not resolved
Hi Ravindra,
its not working.
i modified like below both scenarios.
config.Default()
.AddPlugin("entity_encoding", "raw")
or
if i use below code code icon is not displaying in this block to insert URL.
config.For<EditorialBlock>(t => t.MainBody).AddSetting("entity_encoding", "raw")
#221689
Edited, Apr 23, 2020 8:59
Hi Ravindra, Can you please help to resolve this issue.
#221761
Apr 24, 2020 10:21
