Extend Link Editor Functionality
I'm trying to extend Link Editor adding a new link format for phone numbers.
I added a new field to the Link Editor by exending the class EditorDescriptior as shown below:
 [EditorDescriptorRegistration(
        TargetType = typeof(string),
        UIHint = "HyperLink",
        EditorDescriptorBehavior = EditorDescriptorBehavior.PlaceLast)
    internal class CustomLinkEditorDescriptor : EditorDescriptor
            if (!metadata.EditorConfiguration.ContainsKey(("providers")))
                return;
            var providers = (metadata.EditorConfiguration["providers"] as Enumerable<object>).ToList();
            providers.Add(new
                Name = "Phone Number",
                Title = "Phone Number",
                DisplayName = "Phone Number",
                WidgetType = "dijit/form/ValidationTextBox",
            metadata.EditorConfiguration["providers"] = providers;
The result was:
Link Editor
Generated code:
<a href="/EPiServer/CMS/+351914181987">call me</a>
Expected code:
<a href="tel:+351914181987">Call me</a>
Taking into consideration the scenario explained above, is there a way to format the tag generated to meet the html specification for phone number?
Product: EPiServer CMS
Version: 11.13.2.0
#221510
Edited, Apr 20, 2020 12:56
Minesh Shah (Netcel)
Hi Marcelo
Im believe you might need to create your own display template (/Views/Shared/DisplayTemplates)
THe default view looking inside \modules\_protected\CMS\CMS.zip\Util\Views\Shared\DisplayTemplates\
The html is set out as
<%@ Control Language="C#" Inherits="System.Web.Mvc.ViewUserControl<EPiServer.SpecializedProperties.LinkItem>" %>
<%@ Import Namespace="EPiServer.Web.Mvc.Html" %>
<%: Html.ContentLink(Model) %>
You might be able to interate through the providers and output something different if its a Phone Number
#221520
Apr 20, 2020 14:24
Hi Marcelo,
As far as I'm aware, you'll need to add your own Dojo widget. Here is one based very closely on the EmailValidationTextBox:
define("scripts/PhoneValidationTextBox", [
    "dojo/_base/declare",
    "dojo/_base/lang",
function (
    declare,
    lang,
    ValidationTextBox
    var module = declare([ValidationTextBox], {
        // summary:
        //    Represents the phone number input textbox.
        // tags:
        //    internal
        invalidMessage: "Invalid phone number",
        // addTel: Boolean
        //      If true the value will always be prepended
        //      with the tel protocol
        addTel: true,
        validator: function (value, constraints) {
            // summary:
            //		Validate the text input with telephone number validation.
            // tags:
            //		override
            value = value || "";
            if (!this.required && this._isEmpty(value)) {
                return true;
            // replace escaped sequences to enable/simplify regexp validation (\@ or "everythingInHereIsEsc@ped"
            value = value.replace(/\\.{1}/g, "replaced").replace(/".*?"/g, "replaced");
            return module.validationRegex.test(value);
        _getValueAttr: function () {
            var value = this.inherited(arguments);
            if (this.addTel) {
                // make sure the hyper link has tel: prefix
                value = value ? lang.trim(value) : "";
                if (value && value.indexOf("tel:") !== 0) {
                    value = "tel:" + value;
            return value;
        _setValueAttr: function (value) {
            value = value ? value.replace("tel:", "") : "";
            this.inherited(arguments, [value]);
    // Simple and incomplete test for phone number likeness
    // only trying to stop the most common mistakes
    module.validationRegex = /^(?:(?:\(?(?:00|\+)([1-4]\d\d|[1-9]\d?)\)?)?[\-\.\ \\\/]?)?((?:\(?\d{1,}\)?[\-\.\ \\\/]?){0,})(?:[\-\.\ \\\/]?(?:#|ext\.?|extension|x)[\-\.\ \\\/]?(\d+))?$/i;
    return module;
You'll also need to update the WidgetType when you add this to the providers:
providers.Add(new
    WidgetType = "scripts/PhoneValidationTextBox",
Finally, you'll need to add the following line to your module.config (or create one if it doesn't exist):
<module>
  <dojo>
    <paths>
      <add name="scripts" path="Scripts" />
    </paths>
  </dojo>
</module>
As you probably guessesd, the path above should align with the path you saved the JavaScript to (the above would actually be ClientResources/Scripts).
I haven't tested this, but I'm pretty confident it should work and give you the correct formatting.
#221523
Edited, Apr 20, 2020 14:59
Marcelo - Apr 21, 2020 10:46
Hey Jake Jones
We are almost there, your suggestion has helped a lot!!!
It is working fine to add new phone number links, but when I try to edit it, so the value is displayed on External Link.
Do you have any idea why it is happening?
Glad we nearly solved this!
Since this is pretty useful functionality I took the liberty of spinning it off into a blog post: https://jakejon.es/blog/adding-a-telephone-link-option-to-the-episerver-link-editor
You need to do 2 small things, both of which I explained (+ gave an example of) in the post:
  1. Insert the phone link before the external link
  2. Update the validationRegex to start with an optional "tel:" token: (tel:)?
The alternative is that you need to do some more customization in the front-end which I was trying to avoid.
Let me know how it goes.
#221578
Apr 21, 2020 22:33
Marcelo - Apr 22, 2020 14:18
Thanks Jake Jones. It is working perfectly now.
