Emil, it might help a bit if you could tell us more about this requirement - what is it that you are "actually" trying to achieve?
Based on your current description you want to create a block type "definition" but there is no backing model for it? Did a quick test and if I don't set the "BlockType" ModelType property to at least to typeof(BlockData) then that type is yes visible in admin but you can't create it in edit mode.
Hi Emil!
Did you verify that you set AvailableInEditMode to true? This is set to true by default when decorating a backing model with the ContentTypeAttribute.
For a client's project we need to create block types at runtime. This means that we create the block type without a backing model (class). The creation goes well and the block type is visible as a content type in the admin interface. However, the new block type is not available when trying to create an instance of it from the edit interface. I click the "+" icon in the assets pane, but the created block type is not in the list of available types.
Grateful for some insight.
