Synchronisation accross servers for migration steps
As far as I know there is no functionality in Episerver which would provide an infrastructure for migration steps aside MigrationStep, which can be only used to rename a property. Migration in my case includes setting values for new properties, copying values from one property to another (maybe on another page) and so on. Until now I used Scheduled Jobs for this, but it needs to be completely automated and run at startup.
Is there any infrastructure which I can build upon for this, aside from InitializationModule? MigrationSteps are executed on each startup, so I cannot reuse that, I need to ensure that each of my tasks are executed only once and only on one server at a time (in case of multiple servers are starting up). With the latter I am not sure how to achieve with Episerver, is there anything to synchronise across servers?
It is not purely related to CMS, I need to support Commerce Content as well, but as far as the infrastructure is concerned, it should be transparent.
Zsolt
#241040
Edited, Dec 10, 2020 10:44
Technically you can use IMigrationStep in Commerce, with some caveats (it's not officially public APIs, and it is not built to address multiple instances scenario)
#241041
Dec 10, 2020 10:49
I came across that, but it seems like something which is not fully automatic, the administrator have to start it. Or is it possible to make it automatic, without user interaction?
#241042
Dec 10, 2020 10:56
It is. You can add AutoMigrateEPiServer appSettings (and value = true of course) and the migration process will be started automatically.
#241043
Dec 10, 2020 11:09
Sounds like a good idea! One problem is still how can I ensure that it (or my custom infrastructure) is not getting run parallel on multiple instances, how can I do some kind of synchronisation across instances in code? (the point is not to trust administrators to start only one instance after deployment)
#241044
Dec 10, 2020 11:18
That part is actually tricky and not builtin. You can do some custom cross-instance lock, like checking if a special value is added to a table yet, if not, add it, otherwise just wait until it is changed to complete, for example
#244748
Dec 10, 2020 14:14
Ok, thanks for your answer and the ideas!
#244749
Dec 10, 2020 15:35
Commerce team will be looking into that as well (they are already aware it's a possible improvement), so in a future release - hopefully, you can remove the custom lock. But that'll take some time :)
#244750
Dec 10, 2020 15:46
