Geta categories disappear when used on page
I am using the Geta Categories in a page like this:
[CultureSpecific]
[Display(
  Name = "Categories",
  Description = "",
  GroupName = TabNames.Category,
  Order = 10)]
[AllowedTypes(typeof(Categories.Category))]
public virtual IList<ContentReference> Categories { get; set; }
When working locally:
I have dragged a category to the page property Categories and published the page.
When I rebuild the solution and look att the property Categories in edit mode, the category has disappeared.
I have also added:
<add key="GetaEpiCategories:ShowDefaultCategoryProperty" value="true" />
But the categories added disappear when rebuilding the solution.
Has anyone seen this behaviour before?
I am using Geta.EpiCategories 1.2.11
and EPiServer.CMS 11.14.0
#234850
Dec 03, 2020 12:02
Ravindra S. Rathore
Please decorate the property with [Categories]
Like -
public class MyPageType : PageData, ICategorizableContent
	[Categories]
More info - https://github.com/Geta/EpiCategories
#234851
Edited, Dec 03, 2020 12:26
I added the [Categories] attribute and they still disappear after rebuilding the solution.
Also, I do not want to use the [Categories] attribute since I want to be able to drag categories to the property.
It says in the text that the [Categories] attribute is optional: "If you prefer to use the native content reference list editor for your categories you can skip the CategoriesAttribute:"
Also I can see in the database that the categories are still there: ["1b18f203-3a00-48f0-ae5a-8fcd814c763b","17ed2a34-2d6f-4344-a021-bce73170c3cd","14aab268-e36e-457d-a5ac-a9ee46dfb614"], but they only disappear from the edit mode property view and are also not avaliable in page model.
#234852
Dec 03, 2020 13:02
Ravindra S. Rathore
Can you please confirm on below questions-
  1. Are you using the Geta category items when dragging/dropping them?
  2. Which property you are using? Newly added one or the Episerver default category?
#234855
Dec 03, 2020 14:08
  1. Yes I am using the Geta categories which are from CategoryData. They are dragged from the gadget Categories where I have created them.
  2. Same as above.
#234856
Dec 03, 2020 14:21
Hi, Hannes,
Can you please add a GitHub issue to the repo?
#234948
Dec 05, 2020 23:26
I did not have MultipleActiveResultSets=true in the connectionstring and that was the problem. After looking in the epi error log where it said: "System.InvalidOperationException: There is already an open DataReader associated with this Command which must be closed first." it was solved quickly.
#241013
Dec 09, 2020 16:34
