EditorDescriptor table showing content reference id instead of name
Hi Team,
I am using EditorDescriptor attibute as below in one of Page Type.
[EditorDescriptor(EditorDescriptorType = typeof(CollectionEditorDescriptor<Facilities>))]
public virtual IList<Facilities> Facilities { get; set; }
public class Facilities
[AllowedTypes(typeof(FacilityPage))]
public virtual ContentReference Facility { get; set; }
public virtual bool IsDefault { get; set; }
But in CMS edit, users can see content reference id insted of name. Please refer below screenshot reference.
I have tried below link but that approach has some issues. It was not working some times and also facing issues with table grid add/remove if i follow below link changes.
https://gregwiechec.com/2015/12/propertylist-with-images/
Is there any out-of-box helpers method to show page type name property? Or Can anyone please suggest to acheive this.
Suresh B
#241052
Dec 10, 2020 12:00
I guess this addon from Jake Jones will do what you ask: https://jakejon.es/blog/enhanced-propertylist-for-episerver which is based on Grzegorz Wiecheć solution
#244755
Dec 10, 2020 22:16
Ted
The default CollectionEditor widget basically does a ToString() on each item property without any specific formatters. That's why a complex property is displayed as [Object] by default.
ToString() on a ContentReference results in the ID rather then the name of the associated content.
#245691
Dec 17, 2020 18:17
