Unable to switch language in editor mode.
Wen
Wen
I am in the process of upgrading a Epi 7 multi language site to Epi 11, most of the upgrade went ok. Today i noticed a weird issue when switch language in editor mode.
In the old epi 7 site, I am able to switch to a different language via the language selector in editor mode. After the upgrade, this no longer works. Even if i switched the language via the site branch, it is still saying I am not able to edit the content in English and I am 100% sure the content exists in English and I am under English in site branch in editor mode.
And this is the error i am getting "You are working in English, this content is in dansk. To edit it, switch to dansk".
Has anyone had the same issue?
#230359
Edited, Nov 04, 2020 19:44
It's not really a solution, but you could try to switch language using Language Manager:
https://nuget.episerver.com/package/?id=EPiServer.Labs.LanguageManager
Then it's also easier to see available languages for every page.
#230439
Nov 05, 2020 10:30
Wen - Nov 05, 2020 16:41
Hi Thomas,
Thank you for the suggestion, I tried the gadgets, but I believe something is wrong with switching the language in episerver backend. When I switch to English,
the page tree in editor mode is still in Danish.
Wen
Wen
Also I cant even translate a page anymore.
I checked all the requirements on https://world.episerver.com/blogs/ayman-elbadawy2/dates/2019/12/how-to-enable-episerver-11-for-multilingual/
Still no options to do translation.
#230449
Edited, Nov 05, 2020 21:57
Hi Wen,
All the languuages enabled in "Manage Website Languages"?
#230470
Nov 06, 2020 7:11
Wen
Hi Ravindra,
Yes, those are enabled with correct permission. I also made sure the root page had those language enabled for editing in language settings.
#230494
Nov 06, 2020 15:11
Have you solved this issue Wen? We pahsed the same issue after upgrading to the latest version :-)
#293092
Dec 13, 2022 11:17
The same problem over here, how you solved this issue?
#293860
Dec 29, 2022 2:03
Still waiting to get a reply.
#296102
Feb 07, 2023 8:41
Wen
Hi Anawillian,
Yeah I was able to resolve the issue. I think it was an issue with episerverlog.config.
try replace that whole file with below see if it helps.
<log4net>
	<appender name="ErrorAppender" type="log4net.Appender.FileAppender" >
		<file value="c:\\EPiServerLog\\1\\Monitor\\Errorlog-file.txt" />
		<appendToFile value="true" />
		<layout type="log4net.Layout.PatternLayout">
			<conversionPattern value="%d [%t] %l - %m%n" />
		</layout>
	</appender>
	<appender name="StatisticsAppender" type="log4net.Appender.RollingFileAppender">
		<file value="C:\\EPiServerLog\\1\\Statistics\\EPiServerStatistics.log" />
		<rollingStyle value="Date" />
			<param name="ConversionPattern" value="%d|%m%n" />
		</layout>
	</appender>
	<logger name="EPiServer.Diagnostics.StatisticsLog">
		<level value="INFO" />
		<appender-ref ref="StatisticsAppender" />
	</logger>
	<root>
		<level value="WARN" />
		<appender-ref ref="ErrorAppender" />
	</root>
</log4net>
#296116
Feb 07, 2023 14:48
