Problem with two sites within instance: EPiServer.Framework.Web.AspNetAntiForgery.ThrowForgeryException()
Ed
Ed
I have two sites set up. I click on the second site in the admin, selected a page, and I get redirected to a login page for that host. I'm not sure I should be getting that login, but I then login, andI get the following. Any ideas?
This request has probably been tampered with. Close the browser and try again.
Exception Details: System.InvalidOperationException: This request has probably been tampered with. Close the browser and try again.
Source Error:
Stack Trace:
[InvalidOperationException: This request has probably been tampered with. Close the browser and try again.] EPiServer.Framework.Web.AspNetAntiForgery.ThrowForgeryException() +159 EPiServer.Framework.Web.AspNetAntiForgery.ValidateField() +75 EPiServer.Web.PageExtensions.AntiForgeryValidation.PreInit(Object sender, EventArgs e) +62 System.Web.UI.Page.OnPreInit(EventArgs e) +9864246 EPiServer.UI.Util.Login.OnPreInit(EventArgs e) +12 System.Web.UI.Page.PerformPreInit() +38 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +302
#230065
Oct 28, 2020 23:29
Hey Ed,
Some questions for you:
Is there a load balancer involved in this setup of these two sites, or is this like two sites setup on the same box with two entries in IIS?
Are these two sites are pointing to the same database?
What version are you currently using or Episerver?
-Sean
#230766
Nov 12, 2020 22:05
