Extending "EPiServer.Url" class
My client wants to extend "EPiServer.Url" class with the ability to set "rel" attibute.
Their reference on why: https://www.ranktrail.se/blogg/google-infor-nya-nofollow-lankattribut/ ( in Swedish ).
But basicly add support for
rel="nofollow"
rel="sponsored"
rel="ugc" (user generated content)
This affects "Ranking credit" for links in Google Search for example.
Any idea how to do this?
#229582
Edited, Oct 19, 2020 5:10
You could use a propertylist with the url and the option to set the rel attribute
#229587
Oct 19, 2020 12:04
For a single "EPiServer.Url" property?
[ContentType(GUID = "...")]
public class SomeRandomPage : PageData {
    [Display(Order = 100)]
    public virtual Url PageLink { get; set; }
#229588
Oct 19, 2020 12:09
hmmm, that would be overkill I guess. You could limit the amount that could be added to one though ;) But I think might be the easiest way
#229589
Oct 19, 2020 12:14
Cannot accept this solution sadly. The customer has already 5 sites in production that needs this (single solution). And I don't want to force the customer to change everywhere.
Can't you use
https://world.episerver.com/documentation/developer-guides/CMS/Content/Properties/Custom-properties/
And inherit from Url? But I don't know if it's a propertystring or something else as a base property.
#229592
Oct 19, 2020 12:19
A custom property, even if you would inherit from Url would kinda have the same difficulties, as it would still be a different property? In your situation, with sites already in production, you could add a seperate property in which to select the rel and render them together in your view. It is/feels a bit hacky though
#229593
Oct 19, 2020 12:40
Yes. But in my maybe faulty logic, since it still inherits from Url it would easyly be converted to the new type?
I that seems to be the only simple solution sadly. Thanks!
For future refrence. How do I extend Url class?
#229594
Edited, Oct 19, 2020 12:51
How do I extend Url class? Anyone?
I want a dropdown or textbox to set the rel attribute.
#229734
Oct 22, 2020 9:00
Can you somehow do a editor descriptor and add the new field?
[EditorDescriptorRegistration(TargetType = typeof (Url))]
    public class UrlEditorDescriptor : EditorDescriptor
#229737
Oct 22, 2020 9:18
Sameer - Apr 12, 2022 12:55
Have you found any way to add a new field in Edit Link Dialog box of EpiServer.Url property ?
- Apr 13, 2022 5:36
No. I just added a [SelectOne] factory and added a string sadly.
There are some older posts that will give you some tips on how you could do it, but dojo will be involved for sure.... So personally I would pick an easier way.  An old thread, an old post from Anders
#229738
Oct 22, 2020 9:26
