Change url to editmode
Pär Wissmark
Pär Wissmark
workspace_premiumCMP Administrator CertificationCommerce Connect 14 Developer CertificationDXP Administrator CertificationSaaS CMS Developer CertificationCommerce Connect 13 Developer CertificationExperimentation Strategist Certificationworkspace_premiumPaaS CMS Administrator CertificationSaaS CMS Developer (Expert) CertificationSaaS CMS Administrator Certificationworkspace_premiumPaaS CMS Developer CertificationOpal Administrator CertificationOpal Tools Certificationworkspace_premium
I want to change the url to editmode.
http://domain.se/episerver
to
http://editorialdomain.se/episerver
We wont have an editorial server but an internal domain to access editmode, thats at least the current approach.
I know that this could be done in earlier versions of Episerver but it seems like  the only thing that can change is the "episerver"-path but not the actual domain?
I migh be missing something here, any guidance would be helpful.
https://world.episerver.com/documentation/developer-guides/CMS/configuration/changing-edit-and-admin-view-urls/
#229063
Edited, Oct 07, 2020 9:39
What if you just add new domain binding to the Episerver (assuming that it is not publicly reachable) and access site using that domain?
#229128
Oct 08, 2020 6:37
Pär Wissmark
Yes thats what im aiming at, but i I dont get the effect when I change <applicationSettings  uiUrl="http://editorialdomain/secret/CMS/
The external domain is still working when I try accessing edit/admin.
Is there another place i need to change as well?
/P
#229136
Oct 08, 2020 8:15
New domains need to be added to IIS for the site first like Valdis say and then you can manage them in admin mode.
https://webhelp.episerver.com/latest/en/cms-admin/managing-websites.htm
There you can select what domain should be used as edit host and if you have a multiple site setup you can also specify things like what start page / culture to use.
#229138
Oct 08, 2020 8:21
Changing the uiUrl and adding a host mapping of type 'Edit' doesn't stop other host mappings from working. But it will change all generated links within edit mode so all navigation still works.
#229148
Oct 08, 2020 8:58
Oct 08, 2020 9:03
Pär Wissmark
Thanks!
#229152
Oct 08, 2020 9:18
