Hi Mark,
Do you have a customized TinyMCE config? If so, you may want to check the plugins configured for the editor.
I've just tested the ability to add a block to the Xhtml field of another block, via drag-n-drop, and it worked fine.
Here is the code from mine, in case it helps -
NOTE: I use a customized spellchecker init module, so my toolbar config and mappings are in there, don't go deleting your own! :)
using EPiServer.Cms.TinyMce.Core;
using EPiServer.Framework;
using EPiServer.Framework.Initialization;
using EPiServer.ServiceLocation;
[ModuleDependency(typeof(TinyMceInitialization))]
public class TinyMceInitializationModule : IConfigurableModule
// DEV NOTE - Field mapping and menu/toolbar config
// is done in CustomizedTinyMceSpellCheckerInitialization.cs
context.Services.Configure<TinyMceConfiguration>(config =>
config.Default()
.ContentCss("/Static/build/css/styles.css");
config.Default()
.AddPlugin("lists")
.AddPlugin("advlist")
.AddPlugin("epi-link")
.AddPlugin("epi-dnd-processor")
.AddPlugin("epi-personalized-content")
.AddPlugin("epi-image-tools")
.AddPlugin("epi-image-editor")
.AddPlugin("epi-block-tools")
.AddPlugin("autolink")
.AddPlugin("directionality")
.AddPlugin("visualblocks")
.AddPlugin("visualchars")
.AddPlugin("contextmenu")
.AddPlugin("imagetools")
.AddPlugin("wordcount")
.AddPlugin("charmap")
.AddPlugin("insertdatetime")
.AddPlugin("paste").AppendToolbar("paste")
.AddPlugin("link").AppendToolbar("link")
.AddPlugin("anchor").AppendToolbar("anchor")
.AddPlugin("image").AppendToolbar("image")
.AddPlugin("table").AppendToolbar("table")
.AddPlugin("code").AppendToolbar("code");
Hope this helps!
- JJ
Hey Mark,
I recommend you read the Release Notes and upgrade to EPiServer.CMS.UI 11.34.0 or greater which includes this UI Feature;
Keeps the side panes available when quick-editing a block, to enable drag and drop of pages and assets into properties of the block.
Background
Cheers,
Darren
When editing a XHtmlString field on a block, using the Inline block edit, it seems not possible to drag and drop a block into the TinyMCE editor.
Is there some other way of adding blocks to a TinyMCE without having to navigate to the 'normal' block edit view?
Is there some plugin for TinyMCE that allows you to search and add blocks directly?
