TinyMCE code plugin: Is it possible to display the special characters as characters and not the entity number when viewing source code?
Tony Wang
Tony Wang
PaaS CMS Developer Certificationworkspace_premium
When we upgraded to EPi11 from EPi10 the source code view using the "code" plugin started to display html entity number instead of the actual characters for special characters. Is it possible to have the source code view display the characters again and not the html entity number?
/Tony
#207222
Sep 13, 2019 10:33
Tony Wang
I looked into the settings now and it seems that only the width and height options are possible.
#207223
Sep 13, 2019 10:56
Tony Wang
However, the question still stands. Is it possible to show characters and now html entities some other way?
#207224
Sep 13, 2019 11:00
Praful Jangid
There are some of the reserved symbols that must be converted into their html representation. If you see, when I added these symbols
These were converted into following (while viewing in source code).
<p><sup>!@#$%^&amp;*()</sup></p>
You can refer this article for more information related to it
https://www.tutorialrepublic.com/html-tutorial/html-entities.php
#207353
Sep 17, 2019 15:25
Tony Wang
But is there a configuration to show html entities as their actual characters while viewing source code? In the project I am working on there used to be no html entities in source code view. But after upgrading from EPi 10 to EPi 11 the source code view starting displaying html entites instead
#207355
Edited, Sep 17, 2019 15:40
You can use configuration option "entity_encoding"
tinyMCE.init({
entity_encoding : "raw"
#254720
May 12, 2021 4:17
