Hi Jocke,
Could you please send the real code that's using @Html.AlternateLinks ? in your layout (d:\DLAPI\www.com\Views\Shared\Layouts_Root.cshtml:line 30)
Are you using it like: @Html.AlternateLinks()? (Without param contentLink?) then it's cause null reference exception?
// Ha Bui
We started to use @Html.AlternateLinks() on a website.
For the most part it works just perfectly, but it's also filling up the logfiles. Been trying to google the problem but can't find anything I can use. Does anyone here know why and what I can do to avoid it?
Stacktrace
System.ArgumentNullException: Parameter has no value set
Parameter name: contentLink
at EPiServer.Core.Internal.DefaultContentRepository.GetLanguageBranches[T](ContentReference contentLink)
at EPiServer.Web.Internal.AlternateLinksRenderer.GetAlternateLanguages(ContentReference contentLink)
at EPiServer.Web.Internal.AlternateLinksRenderer.Render(ContentReference contentLink, String action)
at EPiServer.Web.Mvc.Html.AlternateLinksExtensions.AlternateLinks(HtmlHelper html, ContentReference contentLink, String action)
at ASP.Page_Views_Shared_Layouts_Root_cshtml.Execute() in d:\DLAPI\www.com\Views\Shared\Layouts_Root.cshtml:line 30
at System.Web.WebPages.WebPageBase.ExecutePageHierarchy()
at System.Web.Mvc.WebViewPage.ExecutePageHierarchy()
at System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage)
at System.Web.WebPages.WebPageBase.<>c_DisplayClass3.<RenderPageCore>b_2(TextWriter writer)
at System.Web.WebPages.WebPageBase.Write(HelperResult result)
at System.Web.WebPages.WebPageBase.RenderSurrounding(String partialViewName, Action`1 body)
at System.Web.WebPages.WebPageBase.PopContext()
at System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c_DisplayClass21.<BeginInvokeAction>b_1e(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult)
at System.Web.Mvc.Controller.<BeginExecuteCore>b__1d(IAsyncResult asyncResult, ExecuteCoreState innerState)
at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult)
at System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult)
at System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult)
at System.Web.Mvc.MvcHandler.<BeginProcessRequest>b__5(IAsyncResult asyncResult, ProcessRequestState innerState)
at System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult)
at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)
/Jocke
