Earlier versions you needed this base class, but you no longer do. You can delete it. Now you can simply do:
[PropertyDefinitionTypePlugIn] public class LocationsProperty : PropertyList<Location> { }
You can read more details about the updated propertylist here
...and if you use it on a POCO class that has urls remember to decorate that field with to avoid serialization errors (url wont be saved correctly)
[JsonProperty]
[JsonConverter(typeof(UrlConverter))]
[Display(Name = "Favorite", Order = 200)]
public virtual Url FavoriteLink { get; set; }
On updating Episerver core to the latest version v11.13.0.0, the ParseToObject method in the PropertyList<T> class is removed. Kindly suggest an alternate for this method.
Thanks in advance.
public class PropertyListBase<T> : PropertyList<T>
public PropertyListBase()
objectSerializer = this.objectSerializerFactory.Service.GetSerializer("application/json");
private Injected<ObjectSerializerFactory> objectSerializerFactory;
private IObjectSerializer objectSerializer;
protected override T ParseItem(string value)
return objectSerializer.Deserialize<T>(value);
public override PropertyData ParseToObject(string value)
ParseToSelf(value);
return this;
